Home > Maintenance & Mods (L322) > Front brake caliper
SparkyPhil
England 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Front brake caliper
Hi
Could anyone tell me the best place to purchase a front caliper for my 2005my V8, I have looked on the net but not getting much info, the only place I could find, lists the front caliper as twin piston? when I know its ony a single. Any info gratefully received.
Phil
Post #109377 25th Feb 2012 7:24pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Dan (Duckworth parts) is your man - look under the site sponsors section of this site.
Post #109392 25th Feb 2012 10:29pm
fisha
You need an ate / teeves calliper .... It's 60mm diameter and single piston.
One version of the part number is BCA4144 for one side. I bought mine recently (refurbed) from brakepartssuperstore.com
Work out about £100 per side but you'll get £30 back per side if you return the old calliper.
There are s one other places that do similar. Its a common component shared by some versions of the BMW X5. V8 or else ...
Post #109395 25th Feb 2012 11:07pm
SparkyPhil
Thanks for the replies, I am on the case today
Phil
Post #109426 26th Feb 2012 9:28am
