Home > Maintenance & Mods (L322) > Changing alternator on 4.4 2003
pretlove
Has anyone done this yet and if so any tips before I start
Mine was giving out upto 17.5 volts which sent everything mental and blew my sidelight led bulbs
So I disconnected the battery as I fitted a new one and now it's just making a noise and not putting out anything Crying or Very sad
So as said any advice will help thanks guys "RANGEISM WILL NOT BE TOLERATED"
Post #108950 24th Feb 2012 8:21am
pretlove
By the way I got a new battery with 3 years warranty for £75 all in from euro car parts Thumbs Up
It may be a little more if your not trade but not much "RANGEISM WILL NOT BE TOLERATED"
Post #108951 24th Feb 2012 8:22am
fisha
Yes - I've replaced the alternator. Before you start ... have you looked at the price of them?
Its a case of removing all ancillary stuff off the front of the engine, unbolting the unit and sliding it out, then sliding the new one back in.
Technically not a difficult task ... just a pain in the ar5e to have to do it all. ( Why they couldn't have a bolt on the side alternator like every other car out there I dont know .... I do wonder if BMW try to design over complexity into things sometimes )
At 17.5V ... sounds like your regulator has gone kaput, and possibly the diodes.
You're not going to like this next bit ...
I think I just threw a brand new regulator for the alternator out last week .... I still have my old alternator sitting on the work bench. I was considering replacing the regulator and the diodes on it to fix it, but I had a hard time trying to find the right diodes. I think with a bit more effort I probably could find them.... but if the regulator has gone ... doh! V8 or else ...
Post #108997 24th Feb 2012 10:59am
pretlove
Thanks I thought as much so radiator out or not ?
I've found a supplier that has sold me a brand new bosch one for £240 all in "RANGEISM WILL NOT BE TOLERATED"
Post #109009 24th Feb 2012 11:25am
pretlove
I hope the radiator don't have to come out as that's a lot of stuff to disconnect Shocked "RANGEISM WILL NOT BE TOLERATED"
Post #109021 24th Feb 2012 12:00pm
That's a bloody good price! Not sure but should be easy enough to do. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #109031 24th Feb 2012 12:26pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I'm fairly sure the rad does have to come out to give access...
Sorry
Post #109033 24th Feb 2012 12:29pm
fisha
I don't remember taking mine out. I ca take the fan and cowl off without removing the rad....
You may as well replace the water pump when you are in there as well, as it's a known failure item. V8 or else ...
Post #109107 24th Feb 2012 3:30pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Alternator - V8
86.10.02
Before disconnecting the battery, ensure all text and cautions in the battery disconnection section are
observed.
GENERAL INFORMATION, Electrical Precautions.
Remove
1. Position vehicle on lift.
2. Disconnect battery earth lead.
3. Drain cooling system
(COOLING SYSTEM - V8, ADJUSTMENTS, Coolant - drain, flush & refill.)
4. Remove viscous coupling.
(COOLING SYSTEM - V8, REPAIRS, Coupling unit - viscous fan.)
5. Remove ancillary drive belt tensioner.
(CHARGING AND STARTING, REPAIRS, Tensioner - ancillary drive belt - V8.)
6. Release clip and disconnect radiator top hose from radiator.
7. Release clips and disconnect radiator top hose from coolant pump and alternator.
8. Position hose aside.
9. Disconnect pipe from charcoal canister purge control valve, release valve from bracket and position valve aside.
10. Release battery lead from securing clip on engine timing cover.
11. Disconnect multiplug from alternator.
12. Remove nut and disconnect battery cable from alternator.
13. Release alternator harness from securing clip on alternator.
14. Remove 6 bolts securing alternator, remove harness securing clip and remove alternator. Discard alternator 'O' ring.
Refit
1. Clean alternator and engine timing gear cover mating face.
2. Lubricate and fit new 'O' ring to alternator.
3. Position alternator to casing, fit bolts securing alternator and tighten to 13 Nm (10 lbf.ft).
4. Connect battery lead to alternator and tighten nut securing battery lead to alternator to 13 Nm
(10 lbf.ft).
5. Secure battery lead into securing clip on engine timing cover.
6. Connect multiplug to alternator.
7. Secure alternator harness into securing clip on alternator.
8. Fit charcoal canister purge control valve and connect pipe.
9. Connect radiator top hose to coolant pump and alternator and secure clips.
10. Connect top hose to radiator and secure with clip.
11. Fit ancillary drive belt tensioner.
12. Fit viscous coupling.
13. Connect battery earth lead.
14. Fill cooling system.
As Fisha said, remove fan & cowl, no need to remove radiator.
Looks like the viscous coupling may require a special tool.
By the way, is it "ray-dee-a-tor" or "rad-e-a-tor"? Jim
2000 NAS HSE
2005 NAS HSE
Post #109567 26th Feb 2012 11:40pm
fisha
Ray ...
As for the fan, you need a tool or bodge that holds the pulley whilst you turn the centre nut.
I made one out of a large piece of flat bar. It has to grab over one or two of the 4 pulley bolts a s they are the only part of the pulley that protrudes that you can get a grip or hold of to stop it turning.
Once off, ( remember, it's an opposite thread for the fan nut ). I puit back on pretty lightly. Just a gentle nip tight. That makes it very easy to get off later... I don't think I needed my pulley tool the last time to undo the pulley nut, the tension of the belt was enought to hold the pulley. V8 or else ...
Post #109730 27th Feb 2012 6:16pm
pretlove
Thanks for all the advice guys .....all sorted now anyway I did end up sliding the rad out and just removing the tensioner
It's not that bad a job once you figure out what's got to come out just a bit of a knuckle scraper and very costly but at least it's done now Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #109808 27th Feb 2012 10:17pm
03rangiemark
United States 2003 Range Rover HSE 4.4 V8 Java Black
pretlove wrote:
...a brand new bosch one for £240 all in
I may be wrong, but as I understand, Bosch doesn't actually make these alternators any longer, but they do completely refurbish the returned cores and resell them.
There are aftermarket ones that are new.
The Bosch factory rebuild that I bought was about $325 US if I remember right.
And they truely do look brand new. 03 HSE Range Rover (U.S. Spec)
Black
All stock
Post #110434 2nd Mar 2012 12:54am
