Home > Off Topic > Blowing head light Bulbs Honda CRV.
Googsy
My wifes car has developed an big appetite for headlight bulbs. Its a CRV . I have replaced 4 so far over the last 2 months . I did use cheapo bulbs though and am going to fit some Bosch ones instead. So hopefully that might solve. Anyone know what else might cause this and possible fix ?
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #108839 23rd Feb 2012 4:38pm
voltage surge...... is there a regulator in the system somewhere..
Post #108842 23rd Feb 2012 4:41pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
cheapo bulbs ...
Post #108844 23rd Feb 2012 4:43pm
Googsy
Stan there possibly is so if it keeps happening you reckon changing the regulator might fix?
Cheers Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #108845 23rd Feb 2012 4:43pm
pretty sure it will...you could put a voltmeter on the headlight socket and start the car a few times ...see if theres any massive spikes in the voltage..
Post #108846 23rd Feb 2012 4:45pm
Googsy
Cheers Stan I mean Scary just realised .....another joker ... will give that a try Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #108848 23rd Feb 2012 4:47pm
scarey no more googsy, following micks lead and changed it..
Post #108849 23rd Feb 2012 4:49pm
Have you changed the pair at once? I.E. if you get one blow, the other will run slightly hotter whilst only one is working. Then when you change the blown one soon after the one that ran hotter will blow! Then the other will run hotter etc etc... Ever decreasing circles...
Trust me, change both bulbs at the same time...
Happens all the time on D3 brake lights... And "New Transit" headlamps...
Craig Thumbs Up
Post #108924 23rd Feb 2012 11:50pm
