Home > Technical (L322) > Suspension fault - 30 MPH max.
PJS
For quite a while my 06 Vogue, TD6, has had a fault with it. On the onboard computer (where messages are shown i.e temperature) it often says "suspension fault - max speed 30mph". It usually happens when the vehicle starts, but is sometimes whilst driving too.
There doesnt seem to be anything physically wrong with the suspension - it doesnt change height randomly or anything like that.
Could it just be a glitch on the system or is there something actually wrong with the suspension?
Has this been a regular problem for the 06 vogue?
Any solutions?
I've had it on diagnostics and the guys at the place i took it to have looked at it and cleaned out a plug somewhere on/under the vehicle. Still no changes.
Help would be appreciated!
Post #61382 24th Apr 2011 1:36pm
oodathort
Dogey sensor
Post #61392 24th Apr 2011 4:48pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
I had this on mine & it was the cork filter on the suspension compressor in the spare wheel well. It was fixed by Land Rover Assistance in about 10 minutes with a replacement filter, which has been modified by Land Rover with a hole in it to stop it happening again as it is a common fault.
Hope this cures it as the filter only costs a few pounds.
Post #61393 24th Apr 2011 5:27pm
PJS
Thanks for that. I'll check it out with the dealer see what they think.
Post #61394 24th Apr 2011 6:01pm
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Just had "Suspension Fault" come up on my screen - no mention of speed?
Stayed on screen for about a minute then went?
Should i be worried? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #61401 24th Apr 2011 6:51pm
brieff faults that come up could be loose connections on the various ecu's and sensors on the range or at worse it could be a failing item. ... - .- -.
Post #61404 24th Apr 2011 7:03pm
jbarton
United States
@xjsracer44- Is there another name for the "cork filter" you refered too? I am having the same issue with my suspension. I have called the dealership and they have never heard of a "cork filter". Any additional information would be apreciated.
Post #108285 20th Feb 2012 5:41pm
ben2012
2005 Range Rover Vogue Td6 Buckingham Blue
If you go into then boot in the spare wheel area, in the middle is a metal box containing the compressor, take the top off and at the back is the silencer, it's tapered and made of loads of little brass balls all stuck together. It's this that gets blocked and the compressor can't release air so can't adjust as it should
Post #108340 20th Feb 2012 10:27pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
From your description, the correct term would be "sintered brass filter", they are commonly used to filter dust and dirt particles out of air. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #108354 20th Feb 2012 11:58pm
blench99
United Kingdom 2005 Range Rover Vogue Td6 Java Black
I had similar problems with my 06 vogue, i drilled a small hole in the filter but problem kept coming up on dash even when codes had been cleared. In the end my local independant dealer found it was a n/s/f levelling valve which i changed, reset codes and has been ok since. Thumbs Up
Post #108402 21st Feb 2012 11:29am
