Home > General > Passenger Wiper Scuffing Windscreen
This topic is locked: you cannot edit posts or make replies.  Down to end
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
I've noticed that my passenger side wiper is scuffing my windscreen at the max wipe then return position and its slowly getting worse. New blades were fitted about 4 months ago and the passenger side has always smeared.
I adjusted the arm position after purchase because it sat too high but since reading the positioning procedure on another thread I've measured mine to be 40mm rather than 58mm as per the procedure. Might that be the cause?
I'd appreciate comments on the measuurement of other peoples blade position, from edge of screen weather seal to blade contact point?
The angle seems not bad at about 90 degrees.
Thanks
Carl
Post #107999 18th Feb 2012 9:24pm
mzplcg
Check out this current thread. Thumbs Up
http://www.fullfatrr.com/forum/topic10025....28f2cb26d9
Post #108025 19th Feb 2012 8:00am
This topic is locked: you cannot edit posts or make replies.  Back to top
