![]() | Home > Maintenance & Mods (L322) > Rear washer - should the flow of water be constant. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
When I hold the stalk in the wash position water only comes out for 3 or 4 sweeps of the wiper - is this normal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35529 ![]() ![]() |
fronts are washed when the headlights are on and you wash/clean/flick the wiper switch.. ... - .- -.
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Rear - same as mine! Water should flow briefly before they wipe, if not the non-return valve isn't working as intended
I wouldn't mind getting any water at all out of mine. |
starman Member Since: 01 Sep 2011 Location: Stockholm Posts: 82 ![]() ![]() ![]() |
Lolo, my rear washer doesnīt work.
@ starman
