Home > eBay & Bargain Spots > GET 'EM QUICK! FREEVIEW TUNERS!
Page 2 of 3 <123>
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Being fairly newto FFRR ownership I didn't realise that there was some hidden software changing but I will try hooking up the camera and seeing what happens. Does anyone know what the "Companion camera" is? It is enabled on my menu screen - I think it might be the venture cam.
Post #106993 12th Feb 2012 7:58pm
nubbin
He's got some more - 5 this time! But, £50 more expensive. Still good value thought!
Post #107516 15th Feb 2012 3:17pm
markdotreed
Dr. Nubbin.... Didn't know you were over here as well..... hello, it's been a while... Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #107518 15th Feb 2012 3:29pm
Yip, 5 more available..
http://www.ebay.co.uk/itm/120860482047?ssP..._500wt_922 Previously..
Post #107522 15th Feb 2012 4:29pm
Johnte
Fitted and working Thumbs Up
Although only 2 holes lined up, so needed to drill 2 new ones Wink
Post #107857 17th Feb 2012 7:56pm
Yes, only two holes line up, but I felt it was secure enough, so I left it with just the two.
The problem I have now is that I can't get a proper signal. I got a picture for a while, but it disappeared. It found a few bbc channels but would not play them. I'll go for a drive and see if I can find a stronger signal, hopefully that is all it is. Previously..
Post #107882 18th Feb 2012 12:40am
nubbin
Double sided jelly tape works as well (very strong stuff!!). Well it's strong enough to keep the boot lip spoiler on my SL55 AMG so I'm sure it'll work for a TV module Very Happy
I have a good signal, with 35 channels instantly available. I did notice that the module is used, not new as it says in the bloke's eBay advert, which I mentioned in my feedback. But, it works perfectly. Does anyone know how to keep the picture format on widescreen 16:9 - it seems to default back to 4:3 when you first turn it on? I've tried changing it with the "753" hidden menu but that doesn't permanently change it
- ooh, I wonder if that's your issue contraband? Is yours set to NSTC rather than PAL?
Post #107915 18th Feb 2012 11:10am
My one appeared to be new.. It had never been screwed to anything as there were no thread marks in the holes. I get options of pal b, c, NTSC etc.. Which pal one should be selected? I'm sure it's just a crappy signal area is the problem. I'm gonna go for a drive now and see what I can pick up... If you know what I mean!! Previously..
Post #107920 18th Feb 2012 11:22am
Working fine now... Just no reception on my drive Razz Previously..
Post #107931 18th Feb 2012 1:15pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
hi guys, does this improve the signal that you get in the car vs the original tuner in there? and also do you get the usual freeview channels? also whats the signal like on the move? sorry for all the q's.....
andy
Post #108400 21st Feb 2012 11:03am
44ark
2006 Range Rover Vogue SE Supercharged Zermatt Silver
can you get an EPG on if so how do you get it up as i cant firgure it out for the life of me Supercharged LPG!!
Post #108401 21st Feb 2012 11:24am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Won a digital tuner on the bay for 210pounds other day, I'll let you know how it works in ire, we don't have many free digital channels yet..but the analogue is being switched off soon so I'm hopeful more channels be added..
Post #108407 21st Feb 2012 1:04pm
The EPG comes on every time you select a channel. It tells you what is on now and next. It goes after about 5 seconds.
Signal on the move is dependant on the signal strength of the area you are in. It comes and goes a bit up here. I only had analogue tv for a month and it was not that great on reception, the digital works much better and clearer in my opinion...... But again, that will be down to signal strength. Previously..
Post #108467 21st Feb 2012 5:45pm
44ark
strange the epg doesnt come up on mine at all Supercharged LPG!!
Post #108619 22nd Feb 2012 2:14pm
simon1233
I also get no EPG on my digital tuner Big Cry
Post #108620 22nd Feb 2012 2:18pm
Page 2 of 3 <123>
