Home > Technical (L322) > Front brake calipers |
Does anyone know what ffrr had brembos fitted and were they always the 6pots or were brembo 4pots ever used??
13th Feb 2012 8:51pm |
2006 - 2009 had 4 pot Brembos on the front. Rears are a standard land Rover item. 2010 had some standard calipers and then in 2011 Brembos were back but larger I think. Now needs 20" wheels cos 19's don't fit over the calipers.
13th Feb 2012 9:16pm |
Well a quick look this morning shows the calipets are twin piston sliding type units so a possible upgrade to some newer 4pots will be on the cards.
15th Feb 2012 11:18am |
It looks like the setup for the sc and 3.6 tdv8 and tdv6/sdv6 ffrr, ssrr and d4 use 360x30mm discs where as the td6 and 4.4 v8 petrols use 345x30mm rotors.
15th Feb 2012 4:25pm |
Well thank you to Dan and Adam(?) @ Duckworths.
15th Feb 2012 9:12pm |
