Home > Maintenance & Mods (L322) > Removal and Refitting of Front Air Susp. - Photo Tutorial |
kerniki Member Since: 13 Feb 2012 Location: south Posts: 1 |
hi from a newbie
13th Feb 2012 9:28am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Yep, it's behind the rear RH wheel arch liner.
13th Feb 2012 9:26pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Did you manage to do the near side without removing the wheel arch liner? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
14th Apr 2014 2:29pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Resurrecting the thread a bit but looks as if I am going to have to do the fronts. Excellent write up Joe.
18th Nov 2015 12:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
A little tip. If your replacing an already punctured bag? Cut the bag with a stanley knife and this will let the air out & negate the need to remove the wheel arch liner and let the air out of the line
18th Nov 2015 12:32pm |
Thanks Craig.
18th Nov 2015 12:44pm |
@ Weegie
18th Nov 2015 5:20pm |
Thanks J90
18th Nov 2015 5:32pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8284 |
You can't really get it wrong, it only fits one way round....
18th Nov 2015 5:40pm |
Thank you. John
18th Nov 2015 5:43pm |
Perhaps need to qualify the alignment point:
18th Nov 2015 10:31pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
could one do a shock absorber change and retain the existing airbags if they are in good condition? do they seperate |
18th Nov 2015 11:11pm |
Absolutely Joe & a fair point BUT... If your lower hub to shocker bolts undo, the strut can easily be changed in around 45mins without the need to remove the liner IF..... The job needs doing as an emergency to get you back mobile again sir, that was my tip for saving time If its a planned job, then thoroughly checking all the other components in the area is of course a good practice and corners should not be cut |
18th Nov 2015 11:40pm |
Don't think that scenario would arise, when either needs changing it wouldn't be worth doing just one, to answer your question yes they do split, Arnott sell just the bag but I've never seen just the shock for sale... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
19th Nov 2015 12:20am |
