Home > General > Uh oh... 03 4.4 V8 - lost power, white smoke, broken down... |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2037 |
Stuart
6th Jan 2010 6:35pm |
Stuart528 Member Since: 14 Nov 2009 Location: North West Posts: 25 |
nope, private sale.... caveat emptor. |
6th Jan 2010 8:16pm |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 |
So sorry mate '09 Freelander 2 TD4 HSE Auto for the Mrs
6th Jan 2010 9:01pm |
inkiboo Member Since: 13 Nov 2009 Location: Aubonne Posts: 80 |
Where in Switzerland are you? I'm in the Geneva/Lausanne area and know the local LR dealers as they have been servicing my FFRR. |
6th Jan 2010 11:21pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1518 |
+1 Headgasket. Gutted for you mate. |
6th Jan 2010 11:39pm |
Thanks all, makes me feel better to know there are at least some people who understand the pain!
7th Jan 2010 11:49am |
I wonder if the coolant in the radiator froze and it overheated? The M62 doesn’t have a reputation for HG failures (although it certainly does sound like that’s your problem) Overall that sucks, you’re correct that the 7 series engine wont fit straight I think they modified the sump for the front diff (bmw saloons being rwd). Overall I wouldn’t expect the HG job to run into the thousands if you get a good indy to do the work. I would also have the vanos unit done whilst the top is in bits.
7th Jan 2010 12:10pm |
Thanks Dan, good suggestion. Freezing is certainly a possibility, car was at 1600m altitude, minus 6 during day probably more at night... Engine came up to temp properly and didn't show any sign of overheating though even once smoke appeared, in fact no warnings on dash whatsoever. I watch the temp needle all the time, because on big old lumps like these it is often the first sign of trouble (had a 735 with a HG problem once, plus a 2.5tdi A6 that went pop...)
7th Jan 2010 2:43pm |
I think you have to do both if you get the head skimmed at all, but you may want to get that fact checked. No ideas on price as I don’t know how many hours a garage would need to charge you for. From a quick google search of “BMW M62 Head Gasket Labour Cost” I’ve seen that one guy was charged $800 in labour plus parts, so if the garage was charging $80PH then that’s 10 hours? I have no idea what a US garage charges, I think £40-£60 is UK indy prices.
7th Jan 2010 3:01pm |
Sadly I don't know any independents as my Full Fat is still under warranty. If you pop over to www.englishforum.ch and ask I'm sure there will offer suggestions; expat community is quite big in Switzerland. Failing that, LR in France will be much cheaper than Switzerland. |
7th Jan 2010 3:16pm |
Real RR Member Since: 13 Aug 2009 Location: In a Defender Posts: 33 |
Stuart,
7th Jan 2010 10:37pm |
Real RR, thanks very much - and very interesting. That guy said he had no driveability issues, and I lost all power on the road... and I also had no engine check light coming on, which he did.
8th Jan 2010 9:07am |
"Anyone know if the X5 4.4 V8 will drop in? Or can I buy a cheap 740 and use that engine? I am sure I have read that this BMW engine was 'ruggedised' for off road use in LR, so not swappable."
8th Jan 2010 10:27am |
Stuart,
8th Jan 2010 11:09am |
