![]() | Home > Technical (L322) > Engine stalls on cold starts |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
Mine has started doing this in the recent cold too, but it seems to be intermittent. I am having my thermostat changed next week as this has died and have been wondering if the two problems are linked. So will see after the thermostat is changed on Monday whether the starting issue still occurs. |
A faulty coolant temperature sensor (CTS) won't affect the reading on the gauge, its function is to monitor the temperature of the engine and feed the correct amount of fuel required dependent on the coolant temperature. When they go faulty they usually over fuel giving a rich mixture. Might be worth having the car plugged into a computer to see if there are any fault codes |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Are you wanting for the glow plugs before starting? Next time it's really cold switch on the ignition to position 2 and put your seatbelt on before starting the car... In the 10 seconds or so it takes you to belt up the glow plugs should have a better chance of starting it...
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Glow plugs on a Supercharged?
When I read this post at first I initially thought glowplugs, but checked the op's car and saw it was a Supercharged. |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
Thanks for your help so far, and an update of this morning's investigations.
Sorry i was using my iPad this morning and i cannot look at your car details...
Yes it does self start and starts ok every time but as the revs decrease down to idle they don't stop at idle but continue to fall all the way to nothing. At that point the engine will either stall which is most common or will just manage to recover to a normal or slightly high idle speed. After that all will be fine even if I restart very shortly afterwards. MY2007 S/C - Stornoway / Jet |
Hmmmm baffling... I would look at MAF? air leaks etc etc... Sorry i cant help further...
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
JustinP had a similar problem with his S/C
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Indeed I did |
Perfect |
Thankfully the problem has not returned |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Sorry to resurrect an old thread.....my SC has always tended to drop the revs and then recover itself. It stalled a few times this (cold) morning though.
