Home > Maintenance & Mods (L322) > swivel lights not working on 200/7 front upgrade
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
i recently bought a 2004 fullfatrr hse to which the previous owner had the 2006/7 front upgrade done. all was done quite well including the headlights.
however there are certain functions, eg the swivelling of the headlight and the cornering lights, on the lights that are not working, which according to the guys who connected the lights could possibly have resulted in the ecu being damaged.
is it possible to get the swiveling of the headlights and the cornering lights to work without causing damage to any other part of the vehicle, and if yes, what must be done?
thanking you in advance
Post #106564 10th Feb 2012 12:45pm
dont think these feature can be activated because the later ranges had different bcu's...
i'm sure craig [cam-tech-craig]knows.... ... - .- -.
Post #106568 10th Feb 2012 12:56pm
landyash
2007 Range Rover Vogue TDV8 Java Black
Hi just like scarey says,they cannot be conected because of the bcu's, possibly the only down side of this type of conversion.
Ash Thumbs Up
Post #106713 10th Feb 2012 9:10pm
Stan in quite right they will not work on any conversion I'm affraid...
Craig Thumbs Up
Post #106768 11th Feb 2012 9:55am
