Home > Technical (L322) > wont fire up
Rolling Ranger
United Kingdom 2003 Range Rover Vogue SE Td6 Atacama Sand
wont fire up
I have a 2003 vogue td6 which is in the garage at moment having work done. It has today had a brand new battery fitted after old one dying totaly. New one now fitted you turn the key all the dash lights up as should but when u turn to key position where the engine should start, NOTHING. Not even a click from anywhere it like the immobilser is on. any ideas would be appreiated. Question the only way is up
Post #10606 6th Jan 2010 7:19pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
sre you have tried but how about unlock and lock and try again are the terinals tight and is the bty defo charged even tho its new
i changed my bty but had no probs
if it does start dont forget full locl left and right to reset the cabration for the EAS
good luck 02 Range Rover HSE Zambezie silver 4.4
Post #10611 6th Jan 2010 7:34pm
Rolling Ranger
The garage have called me and said its the starter motor he is gonna try and rebrush it or something the only way is up
Post #10659 7th Jan 2010 10:20am
