![]() | Home > Duckworth Parts > Battery for a range rover - but it is a Sport! |
I'd suggest to do a search here on the forum as there are many battery related threads. Most important is Ah (capacity) the higher the better and CCA, the higher the better, especially for diesel engines. So first check if you can have a bigger size battery than you have now, I mean physical size and then go for the better brands (but have look around the forum on recommendations of brands and shops). MY 2010 5.0 SC Galway green and sand interior!!
Go for the largest (physical size) Varta or Bosch battery you can get in the space. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
dont know what battery goes onto a RRS....why dont you ask on the RRS forum.. ... - .- -.
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 ![]() ![]() |
Thanks for the input, I will search the web to find out which higher Ah capacity battery will fit without too much needing to change.
i get what you want now, no apologies necessary mate..
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Eurocarparts are still offering 15% off atm |
Thank you very much - I will take a look now... |
