Home > Technical (L322) > Battery charging through tow bar sockets - which pins?
didnt think of the dark knights Laughing , be all right in the summer though.. Mr. Green ... - .- -.
Post #104540 31st Jan 2012 10:57am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
be alright if he parks it under a lampost!
Post #104544 31st Jan 2012 11:17am
supershuttle
Dark Knights - I like it Thumbs Up I think theres one or two on here Whistle Geoff
Post #104551 31st Jan 2012 12:23pm
just noticed my speeling mistack..... Mr. Green ... - .- -.
Post #104559 31st Jan 2012 1:10pm
^^^ what one?
Post #104562 31st Jan 2012 1:40pm
supershuttle
There's me thinking you were making a funny - what a fool I am Very Happy Geoff
Post #104628 31st Jan 2012 4:55pm
supershuttle
So my ctek arrived and car is now charging up - one quick question I assume the 95Ah Land Rover battery in there is a straight forward lead acid thing and I can use the recon function?
I have ordered the 12s plug and will keep you posted - got to say car looks a bit sad with mouth open, much better to stealthily insert something in its rear when no one is looking Embarassed Geoff
Post #104990 2nd Feb 2012 2:31pm
Googsy
Lol Dan can vouch for that Sheep Sheep Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #104995 2nd Feb 2012 2:49pm
supershuttle
Connected the Ctek up through the 12s socket, thanks for all the help and advice Thumbs Up . Battery charged fine will leave connected overnight and use the FBH whilst it is still connected in the morning. Geoff
Post #105624 5th Feb 2012 6:25pm
supershuttle
Ctek was on 7 (never got to 8 ) this morning after leaving connected overnight, activated the FBH whilst it was still connected, stayed on 7 for a while and then dropped back to 4 (7 is only a trickle for a fully charged battery)l. Disconnected after 1/2 an hour car with FBH still on, unlocked and started no problem, lovely and warm inside.
Case closed Very Happy Geoff
Post #105658 6th Feb 2012 10:30am
simon1233
Sorry to resurrect an old thread, but what model of CTEK did you use Geoff? And how did you adapt the cables to be able to plug in through the towing socket?
I have experienced numerous faults this week (ABS fault/Park brake fault/HDC Inactive/Transmission Fault/Transfer box fault/special programs off) which have all resolved themselves. When I checked out the fault codes with my local friendly independent specialist we found loads of codes relating to insufficient voltage for communication between the various ECU's in the car Shocked
I had thought that my new alternator and Bosch 110 amp battery last winter would have prevented this type of problem, but I guess making short journeys is killing the battery and not really providing sufficient time for the alternator to recharge.
Independent Landrover Services in Preston have kindly lent me a CTEK XS 3600, which I have plugged into the car at the moment and hopefully this will resolve most of my issues along with my rechecking the battery connections etc.
I should also say that my alternator seems to be kicking out sufficient voltage, about 14volts and when tested under full load (everything electrical on full power) was still pushing out 12.5 volts at tick over - so I initially suspect the battery.
I guess that as the CTEK they have lent me is only the xs 3600 model, it will only put out 3.6A so will take quite some time to restore my battery...
Post #147004 19th Oct 2012 1:32pm
supershuttle
I eventually bought a new battery - all my problems have gone away!! Geoff
Post #147108 19th Oct 2012 7:43pm
