Home > Maintenance & Mods (L322) > Smoke on Engine off
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Smoke on Engine off
Hi, help!
Just been out, and on stopping had a small plume of white smoke out from under the car (towards the front). Started up again, no smoke nada. Then, turned it off and a the same, a small plume of smoke from the same area.
Saw someone comment before this could be the fuel burning heater, however i'm not sure if i've got one installed? How do i tell and could it be anything else - with twins on the way i'm nervous about a big bill.
Thanks,
Dave __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #105431 4th Feb 2012 2:13pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
if its the front passenger behind the front wheel it could be the heater mines does it when its cold out
Smile
Post #105433 4th Feb 2012 2:18pm
DaveAngel
Simon,
Its around that area, i've read a few more posts like this one http://www.fullfatrr.com/forum/topic5111.html?highlight=smoke and i'm fairly convinced between what you've just said and these.
Going to sit down now and avoid the pending heart attack brought on by the thoughts of replacing exhausts and turbos (PHEW)
Many thanks for the reply!
2015 FFRR SDV8
Post #105436 4th Feb 2012 2:36pm
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Almost certainly the FBH.
I stand to be corrected but I believe all L322 diesels have one fitted.
Mine does the same sometimes. -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #105437 4th Feb 2012 2:37pm
FBH
 Discovery 4 HSE
Post #105441 4th Feb 2012 3:14pm
