Home > General > What Does This Button Do People?
Bomber County
England 2007 Range Rover Vogue TDV8 Java Black
daren't press it in case it's the ejector seat or something tricky...
what does the little button in front of the mirror adjuster thing do?
 - Ad augusta per angusta -
Post #104840 1st Feb 2012 3:30pm
piecost76
It lowers the suspension to access height.
Enables easy getting in & out - I use it when I pick up my mum! Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #104841 1st Feb 2012 3:32pm
Bomber County
ta mate! - Ad augusta per angusta -
Post #104846 1st Feb 2012 4:27pm
AMD
Will only work if all the doors are closed Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #104878 1st Feb 2012 8:13pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
manual also states it should only be adjusted when car is moving. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #104879 1st Feb 2012 8:15pm
johnson1
Appears the debate over only when moving ceases to be a problem on 11MY onwards where it says it can be used stationary too! What did they change, I wonder?
Post #104882 1st Feb 2012 8:36pm
pretlove
Embarassed I thought that was to make the mirrors look down when reversing .....I thought mine didn't work "RANGEISM WILL NOT BE TOLERATED"
Post #104883 1st Feb 2012 8:46pm
johnson1
That should happen automatically Pretlove. It's only the passenger side that dips and the rocker switch must be on the passenger side for it to work. It can be adjusted when in reverse and will remember this position.
Post #104884 1st Feb 2012 9:22pm
It needs to be in the drivers side to work Smile if its in te passenger side position it wont dip Thumbs Up FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104888 1st Feb 2012 9:33pm
johnson1 wrote:
It's only the passenger side that dips and the rocker switch must be on the passenger side for it to work..
Strange both my mirrors dip when going into reverse Neutral
Post #104893 1st Feb 2012 9:47pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
James - I think there's a setting on the MY2010 to specify which mirror or both mirror dips.
Gone - Range Rover Supercharged 2006
Post #104896 1st Feb 2012 9:50pm
I always thought you were a double dipper Mick Wink :p Very Happy
IIRC this is an option as JP has said that can be set on the later models that went to the 10bit system Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104899 1st Feb 2012 9:54pm
Who's James Question
Post #104902 1st Feb 2012 9:58pm
JustinP
http://www.fullfatrr.com/forum/topic9692.html
Post #104904 1st Feb 2012 10:03pm
Laughing Laughing Laughing Forgot about that need to change the title on that post Laughing
Post #104905 1st Feb 2012 10:06pm
