![]() | Home > Maintenance & Mods (L322) > how to convert 2002 to 2006+ front (facelift) |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
ok i said id do a write up on how to facelift so here goes im sorry if its not that easy to follow but ill try my best
you should be left with this ![]() and this ![]() now back to the headlight area the old brakets in the wing need cutting about a bit so that the headlight fits in you can partly make out where in the next pic ![]() some of the old bumper mounts that attach to the wing will need to be cut off you will see the bit i mean very easily when fitting the lights but just to help they are highlighted in the next pic ![]() right you should be pretty much ready to bolt it all back together its just a case of cutting the old plugs for the fogs and fitting the later plugs to the wires and then rewire the headlights.. if you buy these http://www.ebay.co.uk/itm/Late-Range-Rover...224wt_1199 it saves a lot of grief i had of re wiring the lights ...i brought just the plugs and used the diagram below to work out what goes where but id say the above ones are better and they come with the diagram ![]() now its just a case of bolting it all back together and you have a facelift you will be left with a few bolts as the new lights only have 2 bolts holding them in..... and you should end up with this ![]() instead of this ![]() i really hope this helps and i will try to edit anything i think dont make much sense "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
Coulda had some extra beer if you'd have looked at the wiki:
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Hi Pret,
Hi Cliffy,
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
You've done a great job and made it look easy. |
@steve I never brought them plugs as I got mine thrown in with the buy and the diagram I posted is the one I used not powerfuluk one although there pretty much the same apart from the asf wire's that don't work anyway
Thanks Bellini |
I think it looks super. Would be also good to have a similar thread for doing a 2010 conversion at some point when those parts become more affordable. |
Good deal! I'll be over for beer next time I'm in the UK then. Just have to make sure I get in the right car when I leave. Very close looks wise. Seems you have good taste. ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
As do you Steve |
Thanks googsy |
Craig get the finger out |
Toddster Member Since: 18 May 2012 Location: Birmingham uk Posts: 2 ![]() ![]() |
Hi, I've got all the parts for a 06-09 conversion on my 2005.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
have you read this?
