Home > Technical (L322) > Fuel gun keep clicking when refuelling * |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Happens to me with my TD6, I have to rotate gun to the 9o'clock position, even then it may click one or twice on a fill up. |
1st Feb 2012 2:10am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Have you set off the wrong fuel protection.
1st Feb 2012 8:37am |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
Look in your spare wheel well for a yellow plastic thingy which if you insert it into the filler neck, will reset the system.
1st Feb 2012 8:58am |
Same here since I changed from the SC to TDV8 , now all I do is hold the nozzle upside down when filling up problem solved , main reason for it cutting out is due to the air being pushed up and causing the nozzle to shut off when filling the right way ....
1st Feb 2012 9:15am |
I also turn the nozzle upside down |
1st Feb 2012 9:19am |
I must be posher than Mick as I haven't put my own fuel in for moons now FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
1st Feb 2012 10:10am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I had this until the last time I filled up when I pushed the fuel nozzle hard down into the filler pipe and something appeared to click, the nozzle went fully in and I was then able to run the fuel nozzle flat out.
1st Feb 2012 10:59am |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
There is a technical bulletin to cover this fault and ours suffered when we bought it. The bulletin advises about the 9 o'clock position technique but if that fails, as we found, they refit a new neck - all warranty work but quite an involved job! '96 Volkswagen Polo 1.4CL - SOLD
1st Feb 2012 2:12pm |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
Where can i find the technical bulletin? Would it be deemed a manufacturing fault meaning free repair? |
1st Feb 2012 6:18pm |
Hi,
1st Feb 2012 9:05pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6361 |
I had this on mine and told the Dealer while it was under warranty. using the LTB the fuel neck was replaced, but it still happens.
2nd Feb 2012 12:46pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Same here although I barely insert nozzle but any excess depression of fuel nozzle and it clicks. Must try the 9 o clock position Present :2008 TDV8 HSE
2nd Feb 2012 2:49pm |
Careful googsy, I tried that last night after jumping off the top of the wardrobe and nearly killed myself |
2nd Feb 2012 3:25pm |
Another excellent example of how a 'gizmo' on the FFRR impedes use, like TMPS etc.
2nd Feb 2012 3:26pm |
