Home > General > How best to fit front and rear mudflaps
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Got a set of front and rear mudflaps for my FFRR and after a guide or adivse on fitting them, is there one anywhere online?
Want ot get it right and done proper rather than just drill and fit and have rust creep through the following year Sad
Cheers
Post #104028 27th Jan 2012 11:58pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
You will find full instructions on RAVE. If you dont already have a copy good idea to get one. Would have also thought instructions would have been in with mudflaps.
RAVE also downloadable from Wiki
Gary
Post #104110 28th Jan 2012 2:18pm
mrblonde
Cheers 33, do you mean the manuals on CD you can get on ebay? Sorry but new to RR's so still learning
Post #104698 31st Jan 2012 9:24pm
TugRR
Quick word of advice . . . . . .
Rears are easy peasy - allow yourself half an hour for those.
Fronts are "problematic" to fit and require partial dismantling of the inner wing plastic, if you're going to do it properly . . . which it sounds as though you are !
Get the pressure washer under your car before you start - it saves alot of messing about.
It's certainly a worthwhile job once they're on -
Thumbs Up Where do you go after one of these . . . ?
Post #104704 31st Jan 2012 9:31pm
Superspoons
Instructions
Hi,
Not sure where you are in Herts but I've got a set of instructions in the packaging of the front and rear mud flaps that I've never got around to fitting. If you can't get RAVE, drop us a PM and I'll send you a copy of the instructions. Gavin
Post #104705 31st Jan 2012 9:32pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Instructions are also available from the Topix website 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #104721 31st Jan 2012 9:55pm
33CHINACARS
Yes mrblonde RAVE cd from ebay . some have more on them than others. Well worth having.
Gary
Post #104745 1st Feb 2012 1:10am
