Home > Maintenance & Mods (L322) > Which antifreeze?
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Which antifreeze?
I need to top up the antifreeze and don't know what type to use. L322 '53 plate vogue. Serviced by LR so need to make sure I add the same stuff. Don't want to mix it up.
Thanks
Simon "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #104538 31st Jan 2012 10:42am
on the wiki simon under 'recommended lubricants' ... - .- -.
Post #104539 31st Jan 2012 10:55am
MrP
Going to hate myself for asking this - halfords alternatives?...... Crying or Very sad "On first name terms with my local Dealer......now."
Post #104629 31st Jan 2012 4:55pm
dont know, but i'm sure if you go in there with the specs from the wiki they will be able to find something compatible.. ... - .- -.
Post #104638 31st Jan 2012 5:52pm
bjs
Undo the bleed at the bottom of the rad (in corner N/S facing engine) just a little bit and with a white rag in place you will soon see if it's blue or pink... (be careful not to get on you...)
If it's LR serviced I would put money on it being Blue...
Best to be sure though, do not mix.... as for Halfords..... About £30 ish from main dealer, give the girl what she knows to work !!! cheaper in the long run Rolling Eyes
Post #104961 2nd Feb 2012 12:52pm
