Home > General > Rear Wiper on FFRR - Rubbish |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3745 |
what other options are there for it? If you want a wiper hidden out of sight and a split tail gate, the only option is at the top of the screen. The Sport has a wiper at the bottom and doesn't get goo running down it, but then it looks cheap as the wiper is exposed and not hidden away... |
4th Jan 2010 4:16pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6369 |
Another problem with the Sport version is that the widest part of the arc is at the base of the glass, not where the drivers vision is at the top of the glass! IMO, the Sport way is upside down.
4th Jan 2010 4:30pm |
My rear wiper is S t ...... even with a new blade seems as if there is not enough pressure against the rear window ..... |
4th Jan 2010 4:43pm |
might be better with a stronger spring so there's more blade pressure against the screen perhaps? Discovery 4 HSE
4th Jan 2010 4:44pm |
Either that or a new FFRR |
4th Jan 2010 4:50pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
You're not Hawaii yet. |
4th Jan 2010 5:19pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3156 |
I get great wiping by the blade but the water spray bit doesn't work. Any ideas why not? the water pump for the front works fine. does the rear run off the same pump or does it have its own? (I have looked at the schematic but can't find a pump for the rear) |
4th Jan 2010 5:51pm |
sorry, meant to add,...... have had the back cover off adn inspected it and there is no leak. Everything seems normal. |
4th Jan 2010 5:54pm |
If its not leaking, then the jets could be blocked. Try a sewing needle inside them. Note, the rear nozzles do not rotate, they are fixed so don't try and force them.
4th Jan 2010 7:19pm |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 |
I like the way the rear wiper works. I like that it catches the spray and spreads the washing fluid across the screen.
4th Jan 2010 9:07pm |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 |
I love my rear wiper '09 Freelander 2 TD4 HSE Auto for the Mrs
4th Jan 2010 10:09pm |
The no return valve has failed in mine, which means I need to press it twice before I get spray, not exactly the end of the world, but it works fine.
5th Jan 2010 1:57pm |
Often, the spring pressure on wipers is not the way it was originally due to corrosion between the arm and the pivot. Get some penetrating oil and a couple of rags, park your rear wiper vertically and work the oil in by lifting the wiper to 90deg and back until it moves completely freely. I'd be willing to bet you'll see and feel a difference. The rear wipers work fine - except for the end of stroke dribble. But better the wiper than me... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
5th Jan 2010 6:27pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
mine seem to rotate and they move onto no6 Range Rover Everyone needs a hobby |
5th Jan 2010 6:40pm |
