Home > Wheels & Tyres > change of wheels from 19inch to 18inch
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
i contemplate replacing the wheels on the 2004 range rover (19inch - tyres 255/55/19) with that of the 2007 discovery 3 V8 se (18inch - tyres 255/60/1Cool and vice versa, meaning that the range rover wheels must then go to the disco
will the rims fit the respective vehicles without causing problems?
Post #104503 31st Jan 2012 7:45am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Check to see if the wheel nuts are the same. Probably not So nuts stay with their wheels. Also check rim offsets Also different I think. Tyre height will be the same. offset could be 4mm different.
Sure others will correct me if I've got it wrong.
Gary
Post #104567 31st Jan 2012 1:53pm
vnitos
will the offset really make such a big difference.
will appreciate if those who replaced their ffrr wheels with RRS wheels indicate their experience with the changes as the offset on the RRS and Disco3 is the same thus the same difference in offset between the RRS and FFRR wheels
Post #112359 11th Mar 2012 5:15am
i had RRS wheels on mine for over a year with no problems...normal fullfat wheels have a rim width of 8j and 8.5j, and RRS wheels are 9j and 9.5j...this makes the wheel fill the arch much better and gives the fullfat a better stance...dont worry about the offset ,its only 3mm difference..... ... - .- -.
Post #112386 11th Mar 2012 11:07am
