![]() | Home > In Car Electronics (L322) > Re-pinning a Bluetooth module? |
you better give us some picks of what you got, what year is your car... V8 facelift Range Rover Autobiography 22" wheels.
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
Hi, thanks Daveo, it's a 2003, and seems to have wiring in place ( well, a 3-pin connector where the mic should go at least!)
Locating the mic cable is good, but you need the 54 pin connector in back. I assume you've seen that from L322.com? (still available on the way back machine)
Sorry, can't help here... ![]()
A button in the boot is fine - I can't tell you the pins off the top of my head but the info is here in the forum. Or Ajay will be along shortly with the proper pins. (23&24??? Don't know why that just popped up - do not take that for granted though!) ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
hi do you have a bmw ulf module, it then will need the loom repined or have you got the land rover phone module V8 facelift Range Rover Autobiography 22" wheels.
Um, gulp, I can't find a 54 pin connector.... |
the plug will be push right down but only if the car was pre wired for a phone... V8 facelift Range Rover Autobiography 22" wheels.
Thanks Daveo. Well, there is nothing in the space which contains the amp, tv and radio. Had em all out.... Don't think there are any cubby holes etc where it could be hiding.
its a fair job, need to go under the roof lining and various other bits of trim have to come out..have you looked right down, under where the radio and tv tuner are push down as if you was trying to touch the mudflap
your looking for this plug
ulf unit in place
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1976 Harley Davidson Iron Head Sportster |
Thanks Daveo, you are a font of knowledge! Isn't it a metal floor? What do you mean by "push down"? There is some sort of black rectangular box with vents behind the tv and amp (ie towards the wing) should I get that out too? Is there a void under there?
my plug was way down, looking in the boot, on the left where all the nav,radio ect are,you need to push you hand down to the bottom of the inner wing, if you look at my alpine unit with the 2 yellow plugs, under that i have the Sony infra red unit under that you will be in the thick of the loom, you need to dig around there, you now know what it looks like, it must be there as you have the plug for the mic and thats all part of the same loom V8 facelift Range Rover Autobiography 22" wheels.
Thanks Daveo. I'll have a good rummage at the weekend. Not really a job for evenings in this weather! |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
If you can see the white 12 pin connector (X400) and nothing is attached to it then you don't have the phone loom |
Just a quick update to all those who gave me info on this. This kit arrived and I think I have struck gold. It all plugged straight in, and worked first time! It has a 13th gen ULF, and the updated microphone, plus a "remote" button for pairing.
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
sorry to ressurect this thread but does this mean you found the black plug in the end?
am i doomed or is there hope for me? also where did you source the mic from? Thanks Steve 2003 Vogue 4.4 V8 Java Black |
