Home > In Car Electronics (L322) > Any audio experts around today?
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
In my ongoing frustration at not being able to do something simple likeplay MP3s through my non-aux-socket-equipped 06, I bought an inline FM modulator this week. Used them before, they're not perfect, but better than the transmitters. Basically it just plugs inline with the aerial connection and bob's yer uncle. Less interference than a transmitter.
Anyhooooo....I've stripped the dash out to get at the back of the radio (because the modulator needs a cable to the MP3 player/iThing, so you can't really put it in the boot). On the back of my touchscreen unit there are 3 (count 'em) FAKRA plugs as in the pic below:
So I'm thinking, one for FM, one for AM, one for TV?
Except, with the radio on, even with a weak signal, I've pulled them off one by one and it makes no difference to the radio reception! So, which one do I connect to?
Help please! Shortly I'm going to have to put the dash back together, which is not the end of the world but a waste of time if I have to do it again next weekend!
Thanks chaps.
Post #104107 28th Jan 2012 3:08pm
Cappo,
you need to remove the upper tailgate plastic trim on the inside of the car and you'll find the amp in there that you can then plug into IIRC.
Also look at the passenger side rear corner in the boot, open the upper and lower tailgate and put your left hand in and pull the panel off.
You'll see the amp and so forth and i think if you look thru Joe90's post about a carpc you'll find screenshots of the AMP as thats where you want to be.
Think of the head unit as just a screen for the system which sits in the boot and uses the fibre network to talk to each part Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104115 28th Jan 2012 3:43pm
Cappo
Thanks Will, that all makes perfect sense. I'll have a look for the cables later on.
Problem is, the cables on the modulator are quite short so it doesn't lend itself to being sited in the boot. I guess I could probably do it with extension aerial cables and keep the modulator up front - but I don't know whether the extension cables will then act as an antenna anyway and just cause interference.
Aaaaaargh!! Big Cry
Post #104121 28th Jan 2012 4:36pm
before you put them in wrap them in tinfoil and then put them in the car Smile
Or get shielded cables Very Happy
I know the cables you looked at before are 1 for TV, 1 for Reverse camera and 1 for rear/dvd system *i think* Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104125 28th Jan 2012 4:49pm
Martin
Site Admin
If they are on the touchscreen as you say, then they have nothing to do with the audio system and are 3x video cables.
You need to find the radio module.
Martin
Post #104135 28th Jan 2012 5:53pm
Martin
Site Admin
Sorry, which is found by removing the lower glove box.
Just as an aside, do you have an AUX option on the audio screen on the touchscreen, and no socket on the back of the centre console? Or no AUX option button and no socket?
Post #104137 28th Jan 2012 5:57pm
Cappo
Yes, it's twigged with me now that those three FAKRAs on the back of the HU are as you say above.
Martin - no aux on the screen, no aux socket either. No RSE either. The car is firmly in the no-man's-land between model ranges. I know there's the BM54 option but then again, people say buying those 2nd hand is risky, and at £2-300 it's quite a risk just for some music!
I'll talk to the supplier on Monday and see whether the iThing cable can be extended or not; if not, back to square 1.
Post #104148 28th Jan 2012 7:10pm
Same boat as me Cappo its silly the price and setup Sad
Im hoping to get loaded one day and just get a TDV8 VSE instead as much easier! lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104152 28th Jan 2012 7:18pm
Martin
Site Admin
Humour me a minute, do the early touchscreen cars have BMW audio units then?
Can you not do as I suggested and remove the audio unit to get to the antenna connection?
Post #104154 28th Jan 2012 7:25pm
Cappo
That I'm really not sure about Martin........ Confused
Post #104165 28th Jan 2012 8:27pm
Martin
Site Admin
Reason I ask is you mentioned the BM54 upgrade.
Post #104168 28th Jan 2012 8:38pm
Cappo
I think I had read that as being the universal solution to the problem - but I haven't validated it exactly against my car.
Post #104190 28th Jan 2012 11:39pm
