Home > Maintenance & Mods (L322) > How to remove and fit a front parking sensor? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6362 |
One of my sensors keeps falling inside the front bumper, so far I have managed to glue it back in place (the bracket must be broken inside) using a small plastic sucker to keep hold of it and pull it forwards while the glue sets.
27th Jan 2012 2:29pm |
TBH if you do remove it it gives you a good chance to clean it lots of dirt traps and means you can work on it a lot easier, though the is getting it right when you put it back on as even the local RR bodyshop didnt get mine right 2nd time but did it when i went back and took them a bit
27th Jan 2012 2:55pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
I think the parking sensor itself is pushed into the surround from the rear but the parking sensor with surround fits into the bumper from the front so no need to remove bumper but when you push it in there should be ears or tabs to hold it , atached to the parking sensor surround that clip into the bumper maybe your surround is broken ? As i dont think there is anything to break on the bumper its just a hole all from memory but i think im not too far from how it is onto no6 Range Rover
27th Jan 2012 3:01pm |
Speedy,
27th Jan 2012 3:29pm |
I took out the fog light and the number plate plinth, no access allowed, it seems completely sealed off, which is good I suppose for keeping the crap out of the wiring end but a pain when you need access. It's holding for now anyway. Discovery 4 HSE
27th Jan 2012 9:27pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Did you ever figure this out without the need to remove the bumper cover, I have one thats pushed in too and its tripped the park aid and park assist so neither is working.
26th Feb 2019 5:29pm |
