Home > In Car Electronics (L322) > Sat nav code
npikey
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Sat nav code
Ive been given a code that enables you to input address etc while on the move, Wink Thumbs Up ( obviously for the passanger to use ) does it work?? has any one else heard of this?? and are there any other secret buttons or short cuts out there, if it works i'll post it up later Wink
Post #103611 26th Jan 2012 12:27pm
Yeah it does work , there are a couple of codes but can't remember them just now , they are on the forum somewhere ... Thumbs Up
Post #103615 26th Jan 2012 12:31pm
from memory is it 7351? ... - .- -.
Post #103622 26th Jan 2012 12:56pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
1791 Wink
Post #103623 26th Jan 2012 12:57pm
Censored memory i got then... Mr. Green ... - .- -.
Post #103625 26th Jan 2012 12:59pm
rwaw
Where/how do you enter the code ??
Thanks
Post #103686 26th Jan 2012 4:26pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I (or my passenger) can change the address on my sat nav with the vehicle moving without entering a code 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #103752 26th Jan 2012 7:55pm
thats cos you have the older mapping disc andy, the newer 2009/10 upwards discs cant do that because they had firmware upgrades as well... ... - .- -.
Post #103770 26th Jan 2012 9:10pm
Andy_J
Seems like a good reason not to upgrade then, I will now only drive on roads built before 2006 Laughing 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #103776 26th Jan 2012 9:33pm
tbh, the new mapping outways the need to enter on the go ...you can always stop and enter or pre load them and then use 'recent destinations' while on the move... ... - .- -.
Post #103843 27th Jan 2012 8:59am
