Home > Technical (L322) > 2010 REAR LIGHTS |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
what about the side light/ fog light issues V8 facelift Range Rover Autobiography 22" wheels.
22nd Jan 2012 2:02pm |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Hi what sort of issues regarding fog lights |
22nd Jan 2012 3:06pm |
well the side lights and fogs use the same led's but there is a voltage difference to make them dim for side lights and brighter when fogs are used V8 facelift Range Rover Autobiography 22" wheels.
22nd Jan 2012 3:17pm |
Yes sort of its correct that there is around 4 volts on the fogs all the time however the fogs and side lights are on seperate feeds so all you need is a relay on the fog feed
22nd Jan 2012 3:25pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16299 |
Ide like a set or two please if they work... i'll pm you my number...
22nd Jan 2012 5:00pm |
+1 i would like a set as well V8 facelift Range Rover Autobiography 22" wheels.
22nd Jan 2012 5:16pm |
Hi Guys not a problem but this is only the dissco effect issue if you need help with the fogs i can help you with how i got over the problem
22nd Jan 2012 5:38pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
Or if you would like a kit to fix all your issues
22nd Jan 2012 11:02pm |
Hi what does your kit cost and does it encompass all issues
23rd Jan 2012 6:32am |
Hi
23rd Jan 2012 7:45am |
Cost ? |
23rd Jan 2012 7:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35383 |
oodathort, can you pm jr electrics re cost please... ... - .- -.
23rd Jan 2012 8:21am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Commercial Posting - i.e. using this site to promote or sell items - is NOT allowed unless you are a sponsor, via PM or otherwise.
23rd Jan 2012 10:48am |
