Home > Technical (L322) > Check trailer light |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
This appears when I attach the lightboard - the lights are fine. Is this just a warning that activates when a trailer or light board is connected.
21st Jan 2012 6:08pm |
Are they led types at all?? Are any brighter/weaker than the rest??
21st Jan 2012 6:12pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Its picking up a fault somewhere. Normal with LED lighting as they take less power, but if they are bulbs then there is a fault with the circuit...
21st Jan 2012 6:52pm |
I get what Johnte gets exactly. The only LED bulbs are the front sidelights but they are CANBUS friendly so no warnings in normal use even with the sexy shiver when first turning on Geoff |
21st Jan 2012 7:45pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
I have no LED's and mine's a relatively newly fitted Westfalia kit. All I use it for is a bike rack light board & all lights appear to work perfectly.. |
21st Jan 2012 9:11pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
If you get the message then there is a fault on the trailer circuit somewhere. Possibly (if you are lucky) it will be low resistance due to poor connection within the trailer plug and the socket on the car. Cover both liberally with WD40. This always resolved the issues on my boat trailers |
22nd Jan 2012 8:07am |
I do have converter, to convert from 13 pin - maybe that could be the problem ? All the lights are working perfectly (brand new bike rack) |
22nd Jan 2012 10:06am |
