Home > Technical (L322) > trasponder coil |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
when you put the key into the ignition do you here the click to say it has seen the transponder...does the key turn but does not start.. V8 facelift Range Rover Autobiography 22" wheels.
18th Jan 2012 10:32pm |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
it makes a sound of a starter who strives for the battery .... |
19th Jan 2012 8:39am |
when you put the key in the ignition,but do not turn it,,,you should hear a long click ,,, do you get this V8 facelift Range Rover Autobiography 22" wheels.
19th Jan 2012 5:47pm |
autobiorob Member Since: 18 Nov 2011 Location: Peterborough Posts: 33 |
Got exactly same problem. Had new ignition switch and transponder so now narrowed it down to wiring |
19th Jan 2012 9:44pm |
iid with the tool attached I was trying all morning, and I was presented problema.vado to read the diagnostic code and tells me that the relay is dual fuel, then I'm going to order the component will update the post to see if I solved this problem .... |
21st Jan 2012 8:44am |
