Home > In Car Electronics (L322) > Amplifier replacement with Most |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Read this, it might help.. It could be just the BT module..
10th Jan 2012 8:14pm |
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 |
Contraband,
11th Jan 2012 1:07am |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I have the MOST system and had a similar problem which turned out to be the BT module. System froze no radio sound anything, i did a reset of the system by pulling fuses (found a post on here for the correct order) which did come back up and got the sound back but the BT would not work. I got a replacement module of Wiggs and plugged it it worked straight away. I also changed the tv Tuner to a Hybrid Tuner box which is part of the MOST circuit and again all worked straight away without a single trip to the stealer. |
12th Jan 2012 10:56pm |
