Home > Technical (L322) > I got following codes...
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I shelled out $240 for RSW All Comms III. Plugget it in and got following codes that are shown below as screenshots.
Question I have - where can I get description of RR error codes, as well as what causes them?
Here is the list
1. BCU (Body Contol Unit) - the computer that is under passenger seat:
Now, I am going to remove the BCU and send it for repair. This repair supposed to fix all these codes that also cause other problemes, like unable to unlock rear doors and/or tailgate, stiff steering, etc.
2. Engine Control Module:
I was told that these error are caused by failed mass air flow sensor - engine is getting more fuel that it is needed and the result is also poor fuel economy. In addition to mass air flow senser I am also planning to replace power steeing and all fuids - trasfer case, transmission, front and read diff, coolant, engine oil, break fluid.
3. Instrument pack
I know nothing about these errors. What causes these?
5. Steering Interlock Module. Again, I don't know what these errors are about and what are fixes:
6. Transfer Box Module - same, looking for info about these codes
7. Parking Assist Module, not important
Thanks.
Post #691449 28th Apr 2024 6:22am
Weegie
Lists of codes can be found in the workshop manual (download from wiki in red at the top of this page) .
Have you tried clearing the faults to see if they return? They may be faults stored in memory and not cleared John
GAP iiD BT
Post #691451 28th Apr 2024 7:22am
invisible999
I did clear all item fault codes - these that communicate (details below). Most codes got cleared, however some remained.
Following codes remained:
M62 Petrol Engine Module Communications.
Retrieving ECU ID Information.
Returned ECU ID : B8 : F7 : 12 : 8 : E0 : 3 : 5A : DE : 5A : EE : 0 : 0 : 86 :
Misfire detected cylinder 8.
Misfire detected cylinder 6.
Multiple misfire fault.
CAN bus missing node - Instrument Pack.
Body Control Module Communications.
Returned ECU ID : 0 : 10 : A0 : DA : E0 : 3 : 9A : 25 : 10 : 85 : 13 : 30 : 4 : 6 : 32 : B0 :
ECU Part Number : 010A0DA
ECU Hardware Number : E.0
ECU Code Index : 03
ECU Diag Index : 9A
ECU Bus Index : 25
Week of Manufacture : 10
Year of Manufacture : 85
Software Version : 3.0
Servo-valve or connections open circuit
Servo-valve or connections short circuit
Right Headlight Module Communications. Note: worked only on 3rd-4th try to open:
Returned ECU ID : 98 : 10 : A0 : 88 : 38 : 14 : 63 : 40 : 0 : 1 : 10 : 43 : 15 : 8 : 11 : F1 :
Ignition voltage < 7.5 volts.
D2S/R-Light is off.
Followin items could not be opened for diagnostics - the all got the same ERROR : Connection FAILED message
Digital Signal Processor Communications.
ERROR : Connection FAILED...
ERROR : Comms Offline, Please Try Again.
Headlight Leveling Module Communications.
Left Headlight Module Communications.
Lighting Control Module Communications.
Retrieving ECU Fault Information
Satellite Navigation Module Communications.
Rain Sensor Module Communications.
Tire Pressure Module Communications.
The following unites did not get error messages after clearing all fault codes
5HP24 Transmission Module Communications.
Transfer Box Module Communications.
Engine Immobilizer Module Communications.
Steering Angle Sensor Module Communications.
Steering Column Interlock Module Communications.
Air Bag Restraint Module Communications.
Seat Control Module Communications.
Parking Assist Module Communications.
My questions:
1. How much time should I wait to re-check if codes came back?
2. What needs to be done to open communication with items that give ERROR message?
Post #691506 29th Apr 2024 5:47am
garyRR
Can you verify which codes are actually true? For example, it's quite easy to test the car will superlock.
Your diagnostic scanner also doesn't appear to tell you if the codes are present and active or stored.
The earlier L322s are notorious for phantom codes, so I wouldn't believe what it says unless you're experiencing a problem. 2015 Range Rover Autobiography 4.4 SDV8
Post #691511 29th Apr 2024 7:54am
invisible999
Sorry for asking probably dumb question (have not had coffee yet) - how can I test with superlock assuming that i am outside of the locked car? How the test with superlock supposed to be done and prove?
If this about BCU (body control unit) - I have experienced bunch of problem that people say in forums is associated with BCU - after locking unable to unlock rear doors, tailgate and fuel door. Power steering goes stiff rundomly after staring car or in the middle of driving.
That's correct - it is a cable with software under Windows. Not a stand-alone unit. It does not have this functionality. However, if cleaning codes, they are not stored any more, right? So whatever is there after cleaning codes, should be active, right?
Well, here that is really we have - misfire is real thing, I could hear engine sounds awkward. Rear doors, tailgate and fuel door locking/unlocking is real thing - experienced number of times.
The rest - I simply do not know. Also I don't know if all the units that are giving ERROR message when trying to open it to read codes are real problems or can be ignored.
Where can I read more about this?
Post #691548 29th Apr 2024 3:00pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
OP, I'll tell you about those codes I have an answer for:
Remove plastic head covers and:
Check for oil leaks, pooled oil inside the spark plug wells.
Check spark plugs and coils. Any difference in spark plugs colour would be suspect.
Try moving suspect plug / coil to another cylinder and see if the problem moves with them.
Do you have any coolant loss or high pressure in the cooling system? Then a HG failure needs to be ruled out. Hope it's just old or oily plugs and coils
This is normal; will always be there.
D2S/R-Light is off.
Voltage warning is normal; Check and confirm side markers work.
Post #691771 2nd May 2024 3:53pm
invisible999
Hey, thank you for reply and useful info.
Question - what 'HG failure' refers to? Do I need to disconnect battery before checking spark plugs?
'side markers' - do you refer blinkers? BTW, after clearing this message, it did not come back. How long do I need to wait to check if faults coming back?
Also, what about all other units below that are giving ERROR Comms Offline message?
Post #691776 2nd May 2024 4:12pm
vs322
A HG (Head Gasket) failure. I really hope this is not the case.
You do not need to disconnect the battery to work with the spark plugs or the ignition coils. But it goes without saying that the engine should be switched off while you're at it Thumbs Up
By side markers I'm referring to the orange / red (front / rear) side lighted, reflective vertical strip. Being a US market model, I assume it's fitted with those. The 7,5V message may come back once you've switched on the lights. It doesn't seem to affect anything, as I do also get it since I retrofitted US spec sidelight clusters and wired the orange marker bulbs
Unfortunately I cannot be much help with the modules communication error but if the systems in question do actually work, it may just be that the diagnostic tool can't connect for whatever reason...
Post #691779 2nd May 2024 4:30pm
invisible999
Thank you. Head gaskets were replaced/fixed with other engine job costing $5900 1.5 years ago so I do not think it should be the case.
Will move the plugs to see if it is the problem.
Post #691781 2nd May 2024 4:42pm
vs322
Then spark plugs should be your first port of call. I would consider replacing them all, as they may not have been replaced when the HG was done or cheap ones were fitted. I use Laser Platinum NGK BKR6EQUP.
Had my own HG replaced, top end reconditioned and timing chains replaced 26 months ago for about the same amount in €.
Have done 57K Km since and had to change the Denso spark plugs the garage fitted me at around 30K Km.
Post #691782 2nd May 2024 4:52pm
invisible999
vs322 wrote:
A HG (Head Gasket)
Aha, I checked and right one (if facing the vehicle) works, and left one is off. How easy is to replace bulb three?
Post #691969 5th May 2024 3:36pm
vs322
The side light cluster has to come off. It is held in place by a large plastic, oblong retaining nut with fins. Then on the top and bottom of the cluster there are tabs that wedge into the main light chassis.
The most difficult part is undoing and refitting the plastic retaining nut as it is obstructed by the air filter box and doesn't give you enough purchase to handle. The smaller your hands the better. It takes several rounds to unscrew and is easy to slip through your fingers and fall into the undertray; not the end of the world but a nuisance nonetheless. I suggest you find and rehearse a workable grip while undoing, may be quite awkward, but I found that index and middle finger work best although the grip isn't really secure but just enough to pick up and to reposition.
Post #691970 5th May 2024 3:47pm
