Home > LPG > 2008 4.2ltr petrol, 58k miles lpg conversion |
Rodfori Member Since: 08 May 2024 Location: Malta Posts: 3 |
Anyone running a 2008 RR vogue with under 60k miles 4.2ltr? |
12th May 2024 10:05pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1338 |
The issue is whether you can get the lpg for your trip. Personally I think that you’d be just as fine getting a diesel for the long runs and have no worries about fuel.
13th May 2024 6:51am |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 |
I have a 2008 4.2sc which I bought second hand 10 years ago. After a few months had lpg installed and have used it for 72,000 miles locally and around Europe. It works very well but you must use unleaded fairly regularly as well as I may have screwed up my main injectors. When cold outside the car vibrates badly until heat gets into engine. Now it’s warmer it’s better but still noticeable. My Indy will be having a look at them soon. Once they are fixed I will be using lpg around town an unleaded on faster roads. The fact that the car starts on unleaded is not enough to keep the injectors in good condition Current:
18th May 2024 2:04pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1334 |
18th May 2024 4:59pm |
Thanks both for sharing your experiences. I will be taking it to the dealership next wk to have it checked.
18th May 2024 5:21pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2287 |
Have driven LPG nearly all my life. I'm Dutch and in Holland LPG was very normal in all kind of cars. Living in France driving LPG, no problem with finding LPG stations. Normally a LPG car starts on petrol and when warm switches automaticaly to LPG. Any LPG installation has normally te be checked by the authorities, so it's mentioned on the V5. If not mentioned on the V5 you'll might have a hard time getting it trough the local MOT.
18th May 2024 5:34pm |
Hi Dingg1 am only going by what my specialist has told me. As I said it ‘may’ be because I’ve run it on lpg almost exclusively except for start-up for 10 years. Until we get the injectors out it’s only guess work as an extensive check over drew a blank. I’m using the bsg system I believe (may have the letters round the wrong way) I’ve also got the same make on an old SL500, which unlike the 4.2sc, doesn’t need valve saving fluid. Current:
19th May 2024 9:25pm |
Hi Swithins
20th May 2024 9:01am |
Thanks Dinng I’ll give that a go Current:
25th May 2024 6:32am |
