Hello everyone,
I want to check all fuses to make sure that they are no blown. Do I need to disconnect negative terminal of the battery before doing so? I do remember that manual says for SRS fuse 'Do not remove'. What are other fuses that need to be careful around?
Separate question - BCU gets following codes:
Quote:Body Control Unit upper tailgate unlock relay short to battery.
Servo-valve or connections open circuit.
Servo-valve or connections short circuit.
Can any of above be related to fuses?
