Home > Technical (L405) > L405 dynamic response |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
Could someone please tell me why a MY2015 TDV8 Autobiography that I looked at today with a view to buying did not appear to have an option to switch to dynamic response mode? I had this feature on my RR Sport and loved it. |
13th Jan 2017 11:12pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
Not an option in a regal car!
14th Jan 2017 11:08am |
Thanks Nick,
14th Jan 2017 11:57am |
As also said the active dynamics are only fitted to the V8s. The main feature is the active roll control which keeps the car flat in the corners. On the Sport they add a button to allow a different calibration if the roll and damping to make it stiffer. As I said the button is not there in an L405 because it doesn't fit the ethos of the FFRR.
14th Jan 2017 12:33pm |
richardgarth Member Since: 07 Jul 2017 Location: Devon Posts: 2 |
Wasn't sure whether this was standard or an option on the SDV8. I looked at 3 assured used cars in main dealers and none of them could tell me if the vehicles were fitted with it. I had to explain what it was as none of them knew and two tried to say it was the same as Active Dynamics and fitted to all of them! They looked in an old brochure to find out more but couldn't say whether it was fitted. Back to back test drives in a D300 convinced me that it was. If anyone else is in a similar position, download the build sheet and it will be listed as 'Suspension Types - Electronic Air Suspension with ACE (027DQ)'. |
4th May 2024 1:01pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8147 |
It does cost an arm and a leg when the pipes start to leak due to rust, rear subframe out and a lot of labour to change the pipes, it's happening in a lot of the older L405's and all will fail at some point, naked mild steel pipes feed most of it...!!!
4th May 2024 1:22pm |
