Home > Technical (L405) > Problem fitting Ctek direct connector leads
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
I was about to fit one of these with the M6 eyelets to both main and aux batteries but the clamp nuts tighten up as they get towards the top of the stud. I think the stud ends have been peened over. What’s the best way to get the nuts off, just apply brute force? I don’t want to sink stripping the thread of the nut but I imagine it would be tricky to get a die to engage the stud accurately. 2018 L405 4.4 SDV8 Autobiography
2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting….
Post #691144 23rd Apr 2024 11:48am
Could you cut the eyelets so that instead of hoops they become U shaped & slip them over ?
I put mine on the under bonnet terminals. I'm not 100% sure which battery it charges, but as they are the jump starting posts, I assume it's whatever is needed for starting.
https://www.fullfatrr.com/forum/topic55031.html
Post #691149 23rd Apr 2024 12:55pm
Those studs are connected to the main battery...
I don't think I'd connect anything to both batteries, you are in effect joining the batteries together.
I just don't think it's a good idea or they would have just put a bigger battery in...
Maybe I'm miles away but connecting a trickle charger to the main battery always works for me when leaving it for 60days+ It always starts and everything works fine.... Thumbs Up Pete
Post #691160 23rd Apr 2024 4:37pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
If your car has a tow bar you can buy a 13 pin adaptor and just connect your CTek this way which is what I do and it’s so much easier. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #691161 23rd Apr 2024 4:44pm
