Infortainment system dead no light in switch (Now sorted) | |
Good afternoon
After my woes with the fuel pipe, I decided to fit the used DAB module that I bought from eBay. The iid tool showed an internal fault in the module currently fitted in the car.
I swapped them over but did not bolt the replacement unit in, went to the radio, tuned the stations, and it all worked, I have DAB.
Set about bolting everything back in the boot and after all was back together, I thought I would set my favourite DAB stations.
Nothing..... no screen, no light showing on the on and off knob, completely dead.
Could low battery maybe cause this because I had the boot open for quite a while? or maybe a fuse/relay issue. I can't understand how one minute it is fine and half an hour later it is dead.
Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
