Home > Maintenance & Mods (L322) > TD6 L322 High Pressure Fuel Pump Fail / Repair
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
It has been many many moons since I last had any issues with my TD6
BUT
like most things they eventually break !
So heres what happened
I noticed a slight increase in cranking to start engine from either warm or cold - this was only an extra second or two
Driving normal 30mph round town no difference at all
Try to make a quick get away and I could feel a tiny flutter in the revs
So decided to go onto local by-pass and gunned it in Sport Manual mode Razz Well 1st 2nd 3rd and then PING PING PING PING - Engine stopped and total non-start - whoops Whistle
Fuel System Fault on display and had to get a mate to recover me Shocked
Under side of engine dripping wet with pure clean diesel
Back to my workshop and quickly identified leak from High Pressure pump Crying or Very sad
So off I went to consult the Range Rover workshop .pdf, Google, Ebay and Youtube
Off to a local Motor Factors who advertise on Ebay who supplied me with a pump removal / cam chain gear holding tool - £20 Very Happy Bargain
Then let the strip down begin
Detach bonnet struts and lock bonnet in upright position using the tabs on the bonnet hinges
Viscous fan and cowing off
Drain coolant
Rear bulkhead panel off
Inlet manifold off
Partially remove and move away the plastic coolant hose that goes directly over the HP pump
The pump is then clear to remove (no really it is that easy once tha above removed)
Remove blanking plug on front timing chest that covers the HP pump nut
Fit £20 tool which consists of a collar (fit this first) remove nut which is not very tight and then fit support tube through centre of collar
Remove the 3 HP pump nuts but remember to put a piece of masking tape across socket opening to "grab" the lowest nut so it doesnt drop into engine bay
Remove the HP pump to rail metal pipe and the feed and return hoses
HP Pump is NOT "timed" so it does not matter what position the engine is in when removing the pump
Screw bolt into the removal tool and carefully tighten which then releases the pump from the gear which is tapered
A bit of wiggling around and pump is out !!! Thumbs Up
Clean exterior of pump
Then watch YOUTUBE VIDEO's as they are very informative !
Buy a seal kit I paid £16.20 Bow down (cheapest parts bill for an L322 Range Rover)
Failed seal that caused all the grief is pictured next to the 50p
Now I know you are all not going to have access to test equipment but even though I trust my own repair work I still went to a diesel specialist and paid then £20 to pressure test and cycle the pump throughout its working pressure range - 1350 Bar Shocked
Refit and restart engine (doesnt even need bleeding) - check for leaks - NONE Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Hope this quick write-up helps others
Only special tool required is the cam gear holder / pump removal tool
You dont even need to jack up the vehicle or use a pit or ramp
Post #412676 8th Nov 2016 5:48pm
Great stuff, stan will wiki Cool
Link to the custom tool would be helpful Wink .
Post #412714 8th Nov 2016 10:50pm
RS2000CUSTOM
Thanks
Here is a link
http://www.ebay.co.uk/itm/Tool-Hub-1035-In...SwvU5XNEpP
Post #412718 8th Nov 2016 11:05pm
Post #412726 9th Nov 2016 12:15am
RS2000CUSTOM
Yep that's the one Thumbs Up
Post #412727 9th Nov 2016 12:38am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Great write up, thanks for the info. Thumbs Up
hope I never have to do mine Laughing
greg.
Post #412733 9th Nov 2016 6:42am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Thanks for taking the time to do the write-up Thumbs Up 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #412770 9th Nov 2016 11:37am
RS2000CUSTOM
greg.
No probs at all
I have done a couple of similar write-ups for GM Auto Box and EAS
L322's are just big Meccano kits really Laughing
Post #413174 12th Nov 2016 8:56am
sjoconnor
United Kingdom 2003 Range Rover SE Td6 Causeway Grey
So.... it seems that this has happened to my pump.... - drip from pump when running, no drip when not.
How long would you say it normally takes to carry out this repair ?
Cheers
Post #433146 29th Mar 2017 8:16pm
RS2000CUSTOM
Cheers
sjoconnor
I would give yourself a 2 day window
Job is not technically difficult - just take your time 2009 - L322 5.0 S/C Autobiography
Post #433156 29th Mar 2017 9:23pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Suggestion May be this thread should be re -titled INJECTOR PUMP REPAIR as fuel pumps are in the tank.
Post #433457 1st Apr 2017 1:58pm
