![]() | Home > In Car Electronics (L322) > Range Rover 10 pin to BMW 6 and 3 pin CD Changer Harness |
alahmed Member Since: 03 Jun 2012 Location: Jeddah Posts: 62 ![]() ![]() ![]() |
Hello
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
Go to a local scrapyard, dig about in the back of a 3 series BMW (2000 to 2005 ish), behind the panel on the left hand side of the boot and you'll find the cable with the 6 pin and 3 pin connectors. A pair of pliers and a couple of quid to the owner and you'll have what you need. Ten minutes to repin and Robert is married to your Aunt.
Thank you Chris
From memory I think that if you look closely there are numbers on the connectors beside the holes you put the pins into. But I may be wrong. |
Dear Chris
Ok - I've had a look at mine and for the 3 pin plug the terminals go 1 2 3 in the direction of your red graphic - A.
And on your 6 pin diagram the numbers and your letters correspond as:
Thank you so much Chris for your kindness and for your great help.
Sami Saeed Member Since: 10 Jun 2014 Location: Dammam Posts: 2 ![]() ![]() ![]() |
Hi Alahmas .. Hope you are fine & doing well .. I'm wondering if you already installed the Grom adapter and it is functional properly ?? As I'm willing to use mini ipad rather than the outdated RR head unite .. Thx in advance & Best regards |
Yes Sami. Its working perfectly .... ( USB stick as a Virtual 6 CDs , and also the Bluetooth music streaming)
OyabunG Member Since: 06 Jun 2012 Location: Perth Posts: 36 ![]() ![]() ![]() |
Hi, what model Grom unit did you purchase? |
Dear OyabunG
