![]() | Home > Technical (L322) > How to recalibrate EAS |
Ahh but you will, grasshopper, you will!
![]() We try. Usually support through regular channels has been very good too. Don't know what will happen if the IIDTool/EASControl get to iPhone levels of popularity, though. ![]() ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
For Hawkeye do you not need the red or green cable (the one that doesn't come as standard) at an extra cost.
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
We have the red adaptor which will let us look at height sensor data, but we have never seen anything about suspension calibration on the bearmach hawkeye. But we may have missed something?
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
If the dash display goes, you have other problems. Of course, if your laptop failed, you wouldn't be able to use the other tools, either. 6*(one) = 0.5(another)*dozen Jim 2000 NAS HSE 2005 NAS HSE |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Hi Stephen, I have to admit that I've never actually used a Hawkeye. I was going by the official Bearmach literature ( http://www.mailorder4x4.com/acatalog/Hawkeye_Mod.pdf ) which lists 'programming' as an option for the earlier L322. I am also positive that I've also been told by someone that the Hawkeye can do calibration. But I just took the time to look through the manual as well. I seems it can't do calibration. I wonder what they mean by 'programming' then. Sorry if I've caused any confusion. Steve ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Hi Steve,
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3888 ![]() ![]() ![]() |
Am I being smug? - since buying my IDTool I have messed around with the suspension heights to my hearts content - yes, I am being smug because initially I paid for 1 dealer adjustment and it cost me £120 |
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 35 ![]() ![]() |
My 04 TD6 is running about 30mm lower on the rear than the front (which seems to be correct running height) - I'm playing catchup on posts to try to learn about all this, but am I correct in thinking that the cheapest way of proceeding is to recalibrate the suspension height which can be mot cost effectively achieved by the GAP IIDTool..?
If you only have a height sensor down and the lights are still functioning then you only need to replace it and it should work without calibrating |
Hi Craig, thanks for the reply... HIw would I check if a sensor is not working? 2) which lights are you referring to here..? not sure what you mean mate.. |
The original poster stated he needed a new height sensor, so thats what i was answering:thumbsup: |
Craig - this thread is from February 1 1/2 years ago.
Actually, this is not completely true. There are numerous issues that you can end up with if you replace a sensor w/o a calibration. Height sensors are simple potentiometers and in a best case the new sensor will match the old one closely enough so that everything works properly, But this is hit or miss - which is why the official LR procedure is to do a calibration after a height sensor replacement. Yes, the EAS will function after a sensor replacemnt - you can always be parked with one wheel on a curb or whatever, so the EAS can not throw a fault immediately even if new and old values do not coincide. But if the values between the old and new sensor do not coincide, 2 of the more likely scenarios are: that l - if the values are close, the EAS will continually try to adjust the height to bring everything back in line - resulting in premature compressor wear - if the values are further out, sooner or later the EAS will throw a 'height plausibility' fault A calibration is a worthwhile investment. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
