Home > Technical (L322) > FBH - anyone changed the water pump
the_engineer
United Kingdom 2004 Range Rover Autobiography Td6 Buckingham Blue
I have a fault code up saying my FBH water pump has failed. Has anyone got experience of changing it out and is it a big job?
Post #103209 23rd Jan 2012 9:57pm
boffhead
It's quite easy and will take a couple of hours. You will have to take the wheel arch liner off and remove the FBH completely. Once this is done the pump will take a minute.
Chris
Post #103227 24th Jan 2012 6:01am
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi
As above it's really easy to do, just takes time to strip it down.
I just lift car to full height and removed arch liner,
Two water pipes and fuel line, remove silencer and lower bracket.
And then it should slide out, but is a little tight when removing from arch depending on your wheel size.
I have a used but fully working pump if your interested as these are expensive for what they are. RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #103269 24th Jan 2012 11:13am
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
My pump got stuck from lack of use. It came free after knocking on it with a piece of wood from the underside.
Post #103331 24th Jan 2012 4:16pm
the_engineer
thanks everyone.
I am offshore just now so won't be attacking the job until I get home in March. I have a few issues on the car to deal with so just compiling all the info I need until then
Post #104147 28th Jan 2012 6:09pm
