Home > In Car Electronics (L322) > Getting an external hard drive full of movies to play...
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Hi,
Any ideas on how to play an external hard drive (WD passport - USB powered) to play through the RSE system.
Planning to use a laptop but surely there are smaller devices that simply process the data and send it to the RCA ports?
Any ideas,
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #102113 17th Jan 2012 3:46pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
WD TV player
I have the live version with HDMI output that I have plugged into my TV and it plays virtually every format (everything I've ever thrown at it anyway) from the WD passport drive connected to it, IIRC the basic model has RCA output on.
You'd just need a 12v supply for it
Post #102128 17th Jan 2012 4:46pm
EDWARD757
by 12v supply, do you mean an invertor for the power sockets or literally a 12v feed will run it?
Had a good kike at the ones on ebay and they seem great. I guess you can navigate around the different directories on your hard drive using the remote?
This way I can have all the kids films in one place - even driving around the world would not exhaust the supply!!! '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #102150 17th Jan 2012 7:33pm
Katash
Easiest power solution would be an inverter but I'm sure a simple cigar lighter power supply could be made (not sure what voltage they actually run off but its probably 9-12v)
Remote control may be an issue tho as its infra-red so would need LOS from remote to unit or an IR repeater, also if the unit powers off completely it goes through a longer boot sequence when powered up (about 30 seconds vs about 5) so permanent supply may be better, but this may cause battery drain if you forget to put it into standby.
I'm looking at buying my first FF in the next few months (06My SC hopefully) and am also looking at media player integration but wanted more functionality (web, email etc.....) was originally considering this route but now I'm thinking of a Car-PC build based around the soon to be released Raspberry Pi units.
Touchscreen integration would be nice tho which is the biggest hurdle but I have read how somebody fitted a transparent touchscreen layer over the top of the original one, the finger pressure operates both layers so OEM menus work fine but when in aux mode the top layer controls the car PC.
edit: Yes you can navigate dir's via the remote, I have mine set up at home so that each movie file is in a separate folder and with is is a .jpg file of the DVD cover in a certain dimension spec - that way when you open a dir instead of seeing folder/file icons you see a wall of DVD covers.
I have DVD rips and full HD (1080p) Blu-Ray rips on there.
Post #102159 17th Jan 2012 8:16pm
EDWARD757
bloody genius - almost always, if you can think of a problem, there is a widget on ebay that can fix...
Another option I am considering is a 32GB microSDHC in my HTC Desire S and then a micro USB - TV out (the red/yellow/white) cables to plumb straight into the RSE sockets - meanwhile charging phone from car power.
Any potential pitfalls?
Thanks for all your help so far...
Bet you are looking forward to getting your hands on a SC...how is the search? '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #102160 17th Jan 2012 8:55pm
If you use the micro USB to send the RCA Component outs then you cant charge it up unless its a pass through device, IE the power plugs into it as well..
Post #102162 17th Jan 2012 9:06pm
EDWARD757
The cable in question
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0192138008
has an additional power input port and although they claim you can charge whilst streaming, I do not know! '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #102163 17th Jan 2012 9:19pm
For the price I'd say it's worth a go Smile
For the charging unit make sure it supplies 1000ma as the htc's can take upto about 1200ma without any damage but below 1000ma you will drain it faster than it can be charged. I found this with a 700ma unit when using my wildfire for satnav on long journeys!
Post #102167 17th Jan 2012 9:39pm
I do a similar thing with iPod/iPhone - I have a lead that charges & plays out of the RCA rerminals Very Happy
Post #102331 18th Jan 2012 9:00pm
Katash
Quick question, did the MY 06 SC have rear AUX inputs?
Post #102335 18th Jan 2012 9:20pm
EDWARD757
I would imagine it would if it has Rear Seat Entertainment. '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #102347 18th Jan 2012 10:44pm
44ark
2006 Range Rover Vogue SE Supercharged Zermatt Silver
could always use one of these
http://compare.ebay.co.uk/like/20063530063...p;var=sbar
its a sumvision Cyclone pocket plays everything and comes with the correct leads to plug into the AUX in should also run of a cigarette lighter socket ive got one but just have not had time to test and fit yet. Supercharged LPG!!
Post #102389 19th Jan 2012 10:31am
Dogman
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
I give these to our engineers as basic AV source/test device as they'll run from 240/12v and output analogue video & audio or HD HDMI......don't know how much they are now but they were £20-25 and also have IR remote.......great & small, bargain for the price IMO.
Post #102518 19th Jan 2012 9:58pm
