Home > Maintenance & Mods (L322) > Rear propshaft repair?
ggdtr5
2004 Range Rover Vogue Td6 Zermatt Silver
Just before Xmas my rear propshaft failed. Turned out to be the front cv joint, the rubber boot had split letting in water etc and then failing.
The RAVE book says that these are sealed units no replacement available and a new propshaft is required - at a cost of £800+vat. I could not get a new one and ended up getting a 2nd hand one from a breakers yard.
Anyway I had a look at the old propshaft and it was pretty easy to remove the defective cv joint but where do I get a replacement joint?
Has anyone carried out a repair on rear propshaft or any ideas where I might get a replacement cv joint
Regards Graham
Post #101404 12th Jan 2012 6:49pm
There are a number of companies who specialise in repairing prop shafts
Post #101412 12th Jan 2012 7:13pm
My dad did his on his disco. Will ask him where he got his from. I'm sure he just replaced the bearings as the other parts were ok. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #101420 12th Jan 2012 7:29pm
