![]() | Home > For Sale & Wanted > RR 2010 Side Step Trim |
As a last resort you could try a bit of filler so as to mould it into a shape that would cover the area were the piece is missing. You could then sand it until you get the desired shape contour. To finish off you could paint it black so it is not obvious thats what I would do. You could also cover it with a pit of black PVC tape to make it less obvious. Present :2008 TDV8 HSE
petefromtheblock Member Since: 12 Jan 2012 Location: UK Posts: 5 ![]() ![]() |
That would be a good idea, but sadly I am selling the ar and the buyer wants it fitted with hte piece of trim |
I have seen those for side step trim pieces for sale only problem you have to buy them as a set will try and find them if it's the right thing I am thinking off |
Pity he saw it witout trim then you could have removed on both sides and replaced with tape. I wouldnt be too upset if the car in general was good if only a tiny bit of trim is missing. Present :2008 TDV8 HSE
Yeah it is a pain that I did not notice it before... The car is mint other wise.
Sounds like the kinda of buyer you will
This is what i am talking about , don't know if it's what you are looking for tho …. and you do not need to buy a pair
Ah, sadly that is not it.
Are you talking about deployable side steps or fixed? Or are you looking at side skirts with jacking point covers on the design pack?
These are the fixed side steps |
Do you have a picture of them |
Mick You are a star! I've needed these but thought I would need to buy a new step as this bit has broken on mine. What a find! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/] 04, 4.4V8, Vogue Oslo Blue with LPG. "You can sleep in your car, BUT you can't race your house!!!!" If something can't be fixed with a hammer....... You have yourself an electrical fault! |
