Home > Off Topic > DVD ripping |
I'm trying to rip a few DVD's for my son to watch in the back of the car. I've downloaded "Handbreak" which looks pretty good but every time I try and rip a DVD it says it cant due to copyright. Am i being stupid or is there a way to do it? I don't want this for making dodgy DVD's or anything like that just want to keep my son entertained in the back of the FFRR. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
4th Jan 2012 7:50pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Rob
4th Jan 2012 8:12pm |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
DVD decrypter does the job for me. There's only been one or two out of a few hundred that it failed to break the copyright on. If the ripped .ISO image is bigger than 4.7GB, then use a program called DVD shrink which lets you take out extraneous bits like trailers and you can reduce the quality of the main feature to make it fit on a single layer DVD-RW. You'll also need some thing like "magic disc" which will let you mount the ISO image in a phantom DVD drive while doing the shrinking but its all pretty easily done. |
4th Jan 2012 9:33pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Or you could use double layer DVDs. I find Verbatim DVD +r DL work pretty well. They hold 8.5Gb. Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
4th Jan 2012 9:44pm |
Allycraven, purpose of handbrake is to convert DVD to digital format for use on iPod/iPad computer etc, bit more portable than carrying around a stack of ripped DVDs |
4th Jan 2012 9:45pm |
There are some good free tools out there, just google them and try.
4th Jan 2012 11:04pm |
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 |
Try 'Any DVD' from Slysoft. 2006 MY Autobiography. With 'toys'
5th Jan 2012 12:18am |
I know what Handbrake is, but not much use if the OP wants to use the RSE system. Couldn't tell from his post if it was on a mobile device or the In built DVD. |
5th Jan 2012 2:10pm |
It's for both but the main reason is to put on my aftermarket TV tuner via USB pen. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
5th Jan 2012 2:55pm |
"Free-ist" way is to use Linux having installed the decryption setup and them use ffmpeg or mencoder scripts to rip to file. If you have the original DVDs (which you do ) then file size is not an issue, only quality Happy to advise if you want to go this route. .
5th Jan 2012 5:32pm |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 740 |
DVD Shrink is another good free pc based ripper, I use it to take off alll the annoying previews and menus at the start of a film for the little one, great fro the RSE as the disk just starts at the beginning of the film rather than having to go through the menus. 2021 P400 Silicon Silver AB
5th Jan 2012 5:46pm |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 |
I use DVDFab to rip the DVD onto my hard drive and then Handbrake to convert it to MP4. DVDFab is free for ripping DVDs and $40 for Blu-ray discs. It's really easy to use - load the disc, it detects which part of the disc is the movie, click next and away you go. Once done, point Handbrake at the files on your hard drive created by DVDFab. Paul
6th Jan 2012 9:58am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Mp4 will play on iPad & iPhones, correct? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
8th Jan 2012 11:50am |
MP4 files are not natively supported by the iPad/iPod IIRC, you need to use a program like handbrake to convert an existing MP4 file to a compatible codec or use handbrake to encode a DVD to a suitable format in the first instance |
8th Jan 2012 2:20pm |
