Home > General > problems problems .problems
Just noticed you are in Alexandria, would that be Dumbarton or Egypt?
If Dumbarton give this in Larbert guy a call
John at Progrip 01324 557 071
Post #98426 20th Dec 2011 9:33am
Dolphinboy
I had all these lights come on all of a sudden. In my case it was most likely the ABS sensor on the front left wheel. The lights went out after I took the wheel off - check for chafed ABS wiring or the connection to the ABs sensor box just in front of the passenger side windscreen at the rear of the engine bay.
Also check your connections to the battery. Part of my problem was the neg pole wasn't tight enough adn kept shorting out.
Post #98440 20th Dec 2011 10:11am
the_engineer
United Kingdom 2004 Range Rover Autobiography Td6 Buckingham Blue
wish that had been written before i repositioned the wheel.
It is Alexandria next to dumbarton. who is larbet?
I wasn't aware the the 4 wheels needed to be aligned at the same time. Newbie to 4x4. Thanks for the info.
I will have a look at the sensos when weather permits
thanks
Post #98481 20th Dec 2011 1:27pm
Just posting to agree that the wheel need to be in correct position where the mark is and THEN get the 4X Wheel alignment carried out.
Post #98483 20th Dec 2011 1:41pm
Larbert is next to Falkirk. John knows his stuff and has the computer to check the sensor angles etc. Thumbs Up
Post #98484 20th Dec 2011 1:44pm
the_engineer
car is booked in to have the wheel alignment done but won't be until after xmas. Changed the ABS sensors today as a matter of course, wasn't them so thats one thing ruled out. Just need to wait until the alignment is done now to see if that solves anything
Post #99155 23rd Dec 2011 6:02pm
Who is going to be doing the alignment?
Post #99158 23rd Dec 2011 6:35pm
the_engineer
company called acs near glasgow. Not exactly local to me but the say they specialise with their super cooper laser alignment machines. Costs between 90 and 130 depending on what model of rangerover it is
Post #99176 23rd Dec 2011 8:46pm
