Home > Maintenance & Mods (L322) > My RR TD6 run out of battery, help.
J.Seven
Portugal 2003 Range Rover Vogue Td6 Monte Carlo Blue
My RR run out of battery, four weeks stoped. I know these cars are not plug & play like any other car to run cables from one car to another. Please let me know the best procedure in order not to damage the electrical system. The presence lights insie the cabin are vey low and the engine wont crank. Thanks in advance. J.Seven
Post #97303 12th Dec 2011 5:00pm
No different to any other car to jump start, you just need another car and a set of jump leads.
Just connect the jump leads to your car at the bulkhead +ve connect point and to the earth stud on top of the suspension mount.
Once connected run the other car for a few minutes at 1500rpm and then start your car. Then replace your car's battery.
Best of luck. Smile
Post #97314 12th Dec 2011 5:46pm
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
Respect polarity: connect one cable between donor car positive-red battery born to the positive-red one of the RR, start the donor car, connect the other cable to the negative-black battery born of the donor car and the negative-black born of the RR, let it sit for some minutes: the charging system of the donor car will now be charging the battery of the RR; start the RR after a few minutes.
Disconnect the black-negative cable first completely, afterwards the red-positive. RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #97315 12th Dec 2011 5:52pm
as ron says,deffo do this
let it sit for some minutes: the charging system of the donor car will now be charging the battery of the RR; start the RR after a few minutes. ... - .- -.
Post #97320 12th Dec 2011 6:03pm
J.Seven
Thanks for the feedback. This battery is original with 6 months old. Don't think I Will need a new One!!!!! Well, I hope so!! J.Seven
Post #97328 12th Dec 2011 6:27pm
