Home > In Car Electronics (L322) > Blue tooth problem
npikey
Blue tooth problem
I got a modified bluetooth module from wiggs which has been workin ok till yesterday, when i make a call the radio cuts out and then after 4-5 seconds comes back on ignoring the call which is still active on my handset, while this is going on i cant hear anything from the caller and they cant hear me unless i transfere to the handset,
any ideas please, Crying or Very sad
cheers Nick
Post #96178 4th Dec 2011 9:03pm
A1GSS
Suggest you PM Wiggs.... Question Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #96190 4th Dec 2011 9:34pm
npikey
Yeah Cheers, Wink
Post #96270 5th Dec 2011 9:46am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
I have exactly the same problem - I've just bought a 2005 vogue, and the bluetooth connects very well (Samsung Galaxy S2) but is soon as I make a call, the car phone ends the call, but it continues on the handset. I was intending contacting Wiggs to get an updated BT module, but now I'm not sure if it will help. npikey - did you manage to solve the issue?
Post #103244 24th Jan 2012 9:18am
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Im in the same boat nubbin - would love to find out what happened.
Try this though, crazy.
With BT on, make a call on your phone ask them to hang on a sec.
then press the Green Phone on your screen and it redials the same persons number through BT
It should go straight to message bank (as they're on the phone to you)
Leave a quick message (so the message/call doesnt cut off)
And then transfer back to the primary call
BINGO - Bluetooth works through the car, sounds great.
Only while you have two call going at once.
When the message bank gets fed up on the secondary call and hangs up, it will bump you out of BT and you're back to Square one.
MY05 Vogue MOST Touchscreen
Post #119265 27th Apr 2012 1:43am
nubbin
How on earth did you discover that!? Thanks for the tip but I bought a new BT module and it solved all the problems instantly with perfect call making and reception, reliable connection and contacts list available.Definitely worth shelling out the money!
Post #119284 27th Apr 2012 8:59am
wiggs
Thumbs Up i take it your happy with the 2010 module Question Whistle Bluetooth Exchange www.bluetoothexchange.co.uk
Post #119315 27th Apr 2012 12:46pm
nubbin
Thanks very much wiggs, I am very happy with the result. Easily fitted and solved all my problems. Many thanks for the module!
Post #119316 27th Apr 2012 12:51pm
CBH25
rightio im getting on this train
Post #119408 28th Apr 2012 2:26am
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Mr.Wiggs.... what is the difference between the 2010 module and what is fitted as standard in my 2007 FFRR? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #119415 28th Apr 2012 8:06am
wiggs
Better connectivity for newer phones .. Especially blackberry
Holds 1000 contacts
Shows multiple numbers for each contact
Shows signal strength and provider on screen
Thumbs Up Bluetooth Exchange www.bluetoothexchange.co.uk
Post #119418 28th Apr 2012 8:35am
CBH25
Wiggs got it! Thanks.
now I just need to find the instructions! Can anyone help! L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #121126 10th May 2012 11:02am
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Do you mean these? http://wiggy.getmyip.com/ffrr/help.html Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #121130 10th May 2012 11:07am
CBH25
BRILLIANT JOB, thanks.
I searched but couldn't find it, was I thick or was it sonewhere secret? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #121140 10th May 2012 11:26am
link wiki'ed...thanks for the info jfb.. Thumbs Up ... - .- -.
Post #121142 10th May 2012 11:39am
