Home > Maintenance & Mods (L322) > MK4 -hidden service menue- exacter settings possible?
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi Rangenistas,
my MK4 navigation works very well, fast and correct, except one little thing:
The down counting distance measure- mine in german Meters - until the next turn left/turn right crossing road are not very exact.
Standing 20meters before the road, the system shows me 100meters and counts down very fast until zero and to turn into the road.
Normally it´s no problem because now I am aware of the inaccuracy.
But I think, in the hidden menue you can minimalize this inaccuracy.
When you press SETTINGS in the starting menue and then hold the MENUE button pressed for 8seconds, you are in the hidden menue. There are the deviation coordinates for the system.
Does anybody know, if I´m right and which value must be correct?
Btw: here you have also the possibility to switch the Perspective on - then you have a 3D-Map. XJC, RRV8, Series1 86 and 107% of real pleasure
Post #6261 24th Jun 2009 7:04pm
