Home > In Car Electronics (L322) > Bluetooth bits required
comports
Right - BMW Bluetooth module turned up today but I need to get the other bits before I start to fit it.
Can someone shed any light on where I can get hold of:
Mic
Loom conversion
Pairing Button
Arial
Can someone confirm if I will need the steering wheel buttons to be able to answer calls as I may also need this..!
I think that's all I need..??
Ta.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #94657 26th Nov 2011 9:45pm
mjdronfield
Well, having had my Rangie for 8 days now, this is exactly where I am.
I have the ULM (but I think its a problematic version 1), but I understand you can't just plug it in. I have done a few posts about it.
The wiring is all there on my car, so you too may be lucky.
The microphone will be best bought from BMW, and ideally a "version 2". Not sure of part numbers, but a friend of mine updated his 2001 M5 and the newer version microphone was much better.
I understand you have to buy some phone cradle thing to get the pairing button. Seems a little excessive seems you only use it once (per phone).
Can we not "joint 2 wires" !!!
Good luck.
If you find anywhere in the UK that has all the bits at a reasonable price, let us know.
Good luck
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #94786 27th Nov 2011 8:37pm
